I have a AGOL hosted points layer setup with several attributes. I went into the field maps designer and configured the form for field data collection and this works fine. However, after I collect a point with data, if I go back and select it, I can't see the attributes unless I select "Edit."
Is there some setting somewhere that disables viewing attributes? I've never run into this before as previous layers I've setup work fine.
