So I am building my first Stream Layer output in a Velocity Analtic.
I Go to Add Node, Outputs, Stream Layer --
I have two options for "Stream Layer Configuration"
- Also, publish a feature layer that keeps the latest observation for each Track ID
- Select a related feature layer to provide geometry when the stream layer is drawn in a map
They do not seem to be mutually exclusive. But with the second one checked I go to a "Select existing Feature Layer" dialog. Given this is a new object with a new schema, I am guessing I need the first option not the second. But what exactly does that do for me, and what if I don't select either of these options?
There is a lot to configure downstream in terms of Classifications, Symbology, and Popups. So I am looking for some input on the base way to proceed with the least added effort upstream.
TIA --
