I have created a custom widget with input boxes which creates a graphic on a map. I have a "Trash Can" icon button on the widget which the user can hit to clear the map and all input info in the widget. This all works fine.
I would like to use the widget from the (out of the box) top widget ribbon, which allows for a nice icon button that opens and closes the widget. When the widget is open there is then also a "Close X" at the right top hand corner of the widget.
My problem is that if the user closes the widget using the "X" or the ribbon icon button, the widget dialog box will close but it won't clear and the map won't clear (if the user hasn't hit the "Trash Can" button first). I would like closing the widget to function just like hitting the "Trash Can" button, but I can't see how to capture the closing event.
I have tried using componentWillUnmount and componentDidUpdate but I have not been successful.
I have already seen this post on the widget close event but it is not helping me out -- maybe someone can clarify or elaborate?
https://community.esri.com/t5/arcgis-experience-builder-questions/widget-close-event/m-p/1040177/thread-id/1658
Thanks in advance!
