I tried to run this script for converting a batch of shp files in a folder... But i receive error msg posted below... Kindly suggest...
import arcpy
# Set environment settings
arcpy.env.workspace = r"D:\Work\Test"
#Output Path
outKML = r"D:\Work\Test\new"
# Variables Defined
composite = 'NO_COMPOSITE'
pixels = 2048
dpi = 96
clamped = 'CLAMPED_TO_GROUND'
scale = 10000
for layer in arcpy.ListFiles():
arcpy.MakeFeatureLayer_management(layer, Flayer)
arcpy.LayerToKML_conversion(Flayer, outKML,scale, composite,
'', pixels, dpi, clamped)
else:
arcpy.AddMessage('There are no layer files in '+arcpy.env.workspace+'.')
Error :
File "D:\Work\Test\Test.py", line 13, in <module>
NameError: name 'Flayer' is not defined
