I've used the raster calculator to compare two different rasters, next i want to resample one of the rasters to the cell size of the other and then use the raster calculator again with the same calculation.
Raster calculator works fine on the original rasters, but when i try to use it on the resampled rasters it fails, it gives the message "the table was not found".
Im not sure what this means or how to fix it. Is there another way i can make the rasters have the same cell size other than using the resample tool?
Thank you
