I'm looking for some clarification with regards to spatial adjustments in the fabric. We model tax and lot parcels separately, but in most cases these are identical. We didn't have COGO on the data we migrated so are backfilling this as time permits and I want to optimize how we do this.
My understanding is that the adjustment uses COGO to calculate adjustment vectors of the fabric points. In the case of a tax parcel and lot parcel being identical, the fabric points will be shared between the two sets of lines, correct? Are lines without COGO ignored in the adjustment calculations, but still affected by the adjustment when applied?
If the answer to both of those is yes, then we should be able to only backfill COGO on the Lot lines correct? When an adjustment is run and points moved, since the points are shared all lines shared between points are adjusted, even the ones without COGO.
