| note | generated_note_surveyDescription | <p style="text-align:center;">Name</p><p style="text-align:center;">CHAIN OF CUSTODY</p> | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | |
| note | generated_note_form_submit_text | Submit | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | |
| note | generated_note_form_footer | <a target='_blank' style='color:#ffffff;' href='https://www.esri.com/products/survey123'>Powered by ArcGIS Survey123</a> | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | |
| note | generated_note_prompt_submitted | <p style="text-align:center;"><br></p><p style="text-align:center;"><img alt="undefined" src="data:image/svg+xml;base64,PHN2ZyB3aWR0aD0iNjQiIGhlaWdodD0iNjQiIHhtbG5zPSJodHRwOi8vd3d3LnczLm9yZy8yMDAwL3N2ZyI+PGcgZmlsbD0ibm9uZSIgZmlsbC1ydWxlPSJldmVub2RkIj48Y2lyY2xlIGZpbGw9IiMzMTg3MkUiIGN4PSIzMiIgY3k9IjMyIiByPSIzMiIvPjxwYXRoIGZpbGw9IiNGRkYiIGQ9Ik0yMi42NjEgMzAuMjQ2bDUuMTgyIDQuOTg3TDQxLjU1MiAyMiA0NSAyNS40NjEgMjcuNzQ3IDQyIDE5IDMzLjQ5OHoiLz48L2c+PC9zdmc+"></p><p style="text-align:center;"><br></p><p style="text-align:center;"><strong style="font-size:16px;"><p style="text-align:center;">Thank you.</p><p style="text-align:center;">Your response was submitted successfully.</p></strong></p> | | | | | | | | | | |
| text | sampled_by | Sampled by | <p>(your first and last name)</p> | | yes | This is a required question | | | | | | | | | | | | | 255 | | | | | | | | | | | | | | | | | | | |
| text | client_name | Client Name | | | | yes | This is a required question | | Client | | | | | | | | | | | 255 | | | | | | | | | | | | | | | | | | | |
| text | project_number | Project Number | | | | | | | Permit Number | | | | | | | | | | | 255 | | | | | | | | | | | | | | | | | | | |
| begin group | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | |
| begin repeat | Sites | Select Site | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | |
| select_one list_site_code | select_site | | Pick one: | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | |
| text | sample_description | Sample Description | | | | yes | | | | | | | ${select_site}='Other' | | | | | | | | | | | | | | | | | | | | | | | | | | |
| geopoint | collection_point | Collection Point | | | | | | | | | | | ${select_site} | | | | | | | | | | | | | | | | | | | | | | | | | | |
| image | photograph_site | Photograph site | | | | | | | | | | | ${select_site} | | | | | | | | | method=camera | max-size=10 | | | | | | | | | | | | | | | | |
| dateTime | datetime_sampled | Date/Time Sampled | | | | | | | | | | | ${select_site} | | | | | | esriFieldTypeDouble | 255 | | | | | | | | | | | | | | | | | | | |
| select_one list_regulatory | is_sample_regulatory | Is sample collected for regulatory reporting purposes? | | | | | | | | | | ${select_site} | | | | | | | | | | | | | | | | | | | | | | | | | | |
| select_one list_site_is_site_flowing | is_site_flowing | Is it flowing >1 gpm? | | | minimal | | | | | | | | ${select_site} | | | | | | | 255 | | | | | | | | | | | | | | | | | | | |
| decimal | field_ph | Field pH | | | | | | | | | | | ${is_site_flowing}='Yes' | | | | | | | | | | | | | | | | | | | | | | | | | | |
| decimal | field_conductivity | Field conductivity | | | | | | | | | | | ${is_site_flowing}='Yes' | | | | | | | | | | | | | | | | | | | | | | | | | | |
| select_one list_site_is_flow_calculated | is_flow_calculated | Is the flow calculated? | | | minimal | | | | | | | | ${is_site_flowing}='Yes' | | | | | | | 255 | | | | | | | | | | | | | | | | | | | |
| integer | estimated_flow_rate_gpm | Estimated flow (gpm) | | | | | | | | | | | ${is_flow_calculated}='No' | | | | | | | | | | | | | | | | | | | | | | | | | | |
| decimal | stream_length_ft | Stream depth (ft) | | | | | | | | | | | ${is_flow_calculated}='Yes' | | | | | esriFieldTypeDouble | | | | | | | | | | | | | | | | | | | | |
| integer | stream_width_ft | Stream width (ft) | | | | | | | | | | | ${is_flow_calculated}='Yes' | | | | | esriFieldTypeDouble | | | | | | | | | | | | | | | | | | | | |
| decimal | stream_velocity_ftsec | Stream velocity (ft/sec) | | | | | | | | | | | ${is_flow_calculated}='Yes' | | | | | esriFieldTypeDouble | | | | | | | | | | | | | | | | | | | | |
| decimal | flow_rate_gpm | Flow rate (gpm) | | | | | | | | round(448*(${stream_length_ft} div 2*${stream_width_ft})*${stream_velocity_ftsec}, 0) | | | ${is_flow_calculated}='Yes' | | | | | esriFieldTypeDouble | | | | | | | | | | | | | | | | | | | | |
| select_one list_frequency | frequency_DSTF04 | Sample Collection Frequency: | | | | | | | Quarterly | | | | ${select_site}='DSTF04' | | 0 | | | | | | | | | | | | | | | | | | | | | | | | |
| select_one list_frequency | frequency_USTF04 | Sample Collection Frequency: | | | | | | | Quarterly | | | | ${select_site}='USTF04' | | 0 | | | | | | | | | | | | | | | | | | | | | | | | |
| select_multiple list_bottles | bottles_DSTF04 | Bottles: UFUA = unfiltered, unacidified : UFA = unfiltered acidified : FA = filtered acidified | | | | | 1L_UFUA,120mL_HNO3_UFA | | | ${select_site}='DSTF04' | | 0 | | | | | | | | | | | | | | | | | | | | | | | | |
| select_multiple list_bottles | bottles_USTF04 | Bottles: UFUA = unfiltered, unacidified : UFA = unfiltered acidified : FA = filtered acidified | | | | | 1L_UFUA,120mL_HNO3_UFA | | | ${select_site}='USTF04' | | 0 | | | | | | | | | | | | | | | | | | | | | | | | |
| select_multiple list_analysis | Analysis_DSTF04 | Analysis | | | | | | | Flow,Cond,pH,TSS,Alkalinity,Sulfates,Hot_Acidity,Iron,Manganese,Aluminum,TDS | | ${select_site}='DSTF04' | | 0 | | | | | | | | | | | | | | | | | | | | | | | | |
| select_multiple list_analysis | Analysis_USTF04 | Analysis | | | | | | | Flow,Cond,pH,TSS,Alkalinity,Sulfates,Hot_Acidity,Iron,Manganese,Aluminum,TDS | | ${select_site}='USTF04' | | 0 | | | | | | | | | | | | | | | | | | | | | | | | |
| end repeat | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | |
| text | field_76 | Special Instructions or Comments | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | |
| image | relinquished_by | Relinquished by | <p>Please sign your name.</p> | signature | yes | This is a required question | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | |
| select_one list_site_sample_drop | is_sample_drop | Is there a person to receive the samples? | | | yes | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | |
| text | sample_secure | Sample was dropped at secure location. | Enter any other pertinent info about the samples' drop location. | | | | | | | | ${is_sample_drop}="No" | | | | | | | | | | | | | | | | | | | | | | | | | | |
| dateTime | datetime_relinquished | Date/Time Relinquished | | | | yes | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | |
| image | received_by | Received by | <p>Please sign your name.</p> | signature | | | | | | | | ${is_sample_drop}="Yes" | | | | | | | | | | | | | | | | | | | | | | | | | | |
