I'm trying to load CAD files into ArcGIS Indoors using the CONFIG_CAD_Indoors_Template.xlsx file delivered with ArcGIS Pro 3.1.2.
When I launch the Toolbox Import Floorplans To Indoors Geodatabase I get an error 180161 with the following message:
Parameters
Target unit entities C:\Temp\ArcGIS_Indoors\ArcGIS_Indoors.gdb\Indoors\Units
Target detail entities C:\Temp\ArcGIS_IndoorsArcGIS_Indoors.gdb\Indoors\Details
Target level entities C:\Temp\ArcGIS_IndoorsArcGIS_Indoors.gdb\Indoors\Levels
Target building entities C:\Temp\ArcGIS_IndoorsArcGIS_Indoors.gdb\Indoors\Facilities
Input Excel Template File C:\Temp\ArcGIS_Indoors\test_config_indoors.xlsx
Unique ID Delimiter PERIOD
Sliver Threshold 2
Door Close Buffer 0
Surface measurement unit SQUARE_METERS
PLANAR measurement mode
Target section entities
Target area entities
Updated units C:\Temp\ArcGIS_Indoors\ArcGIS_Indoors.gdb\Indoors\Units
Messages
Start time: Thursday, August 3, 2023 12:09:08 PM
Retrieve floor plan mapping details from an input Excel file...
Retrieve building properties from an input Excel file...
Validate worksheet: Facility Properties...
Retrieve level properties from an Excel input file...
Validate worksheet: Level Properties...
Validate worksheet: Source Files...
ERROR 180161: The Level Properties worksheet cannot contain a SOURCE_PATH column.
Import floor plans into Indoors geodatabase script failed...
Failed to execute (ImportFloorplansToIndoorsGDB).
Failed on Thursday, August 3, 2023 12:09:24 (elapsed time: 16.36 seconds)
It seems that the Excel file is not configured correctly. Does anyone have a solution?
Thanks in advance.
