Last autumn we deployed a new SAN at our org. Ever since then any of my Python utilizing acrpy that writes to, or references, a directory on that SAN using the complete UNC path (//SAN/DIRECTORY/SUB-DIRECTORY/SUB-SUB-DDIRECTORY/ etc.) runs exceptionally slow. However, if I use the drive letter for the path it runs at normal speeds. And when I say slow, I mean when it would normally take a minute or two it now takes an hour or more. And it seems to be limited to the arcpy module.
Below are some run times using UNC/drive letter and shutil/arcpy. The shell utilities module is used to copy a directory with shapefile files in it to the SAN. Arcpy is used to export a featureclass to a shapefile in a directory on the SAN.
Drive Letter and shutil: 0.4070 mins
UNC and shutil: 0.400 mins
Drive Letter and arcpy: 0.150 mins
UNC and arcpy: 103.14 mins
Most of this involves my data management Python that runs on a server. I've rewritten it so arcpy doesn't reference or write anything on the SAN. I just works with the local hard drive. I then use other Python libraries to move, and work with, data on the SAN.
Anyone else experience this? If I had to guess it has something to do with the config of the new SAN.
