I am continuing my journey of migrating from ArcMap Attribute Assistant to the new ArcGIS Pro Attribute Rules. The old attribute assistant had the option to "Link Table Asset" which "updates a field in the table or layer with a value from a selected feature." I found this useful for transferring attributes from an existing feature to a new feature. For example: I would select a street and then create a new point feature for an address. The Assistant would grab the street pre-direction, name, type, post direction, and full name fields and calculate the new address point's fields with the same information, so I only had to manually enter the number and I was done.
RoadCenterLine|PRE_DIR,STR_NAME,STR_TYPE,POST_DIR,STNAME
I was wondering if the Attribute Rules (and Arcade language) has something similar? I have been able to use the Arcade intersect() to pick up and calculate features under my new point. I am aware of the "Transfer Attributes" tool when editing, and that does work, but it is more manual and more steps. I liked the "automatic" transfer the Assistant gave me. Anybody have some suggestions? Thanks in advance!
