Hello, I am having trouble using overlays from a repeat, as discussed in this post about geopoints.
Geopoints
I tried putting "overlay=repeat_name&preview=true" in the body::esri:style column of my .xlsx file using survey123 connect , however, nothing happens when I do so.
I would like to take the first geopoint input and pass it into the next record inside the same repeat or default zoom into that region so that user can easily locate the position and input similar record.
Are there any mistake I made or any other solution to achieve it?
Belows is my xlsx file,
survey.xlsx
Tom
