I have been search for a way to override the popup template on a KMLLayer in the ESRI v4 api for a while with no luck. I am trying to avoid a rewrite of some functionality as we did not know all the constraints on KMLLayers. We would like to preserve style but not showing the extended data or having a way to add actions to the popup is kinda a deal Breaker
I have tried providing a template on creation, have also add this template to allSublayers. I have
also tried overriding the popupTemplate manually on the layer.
const customButtonPopUp = {
title: "sync",
const kmlLayer = new KMLLayer({
url: kmlFileUrl,
title: sitetrackerLayer.Name,
sForceInfo: { Id: sitetrackerLayer.Id, Type: sitetrackerLayer.Type },
popupTemplate: new PopupTemplate({
title: "{Name}",
content: "{balloonStyleText}",
actions: [customButtonPopUp]
I have tried doing this manually on click by setting the content and disabling the popupEnabled property
on the Layer
mapview.on("click", function(event) {
mapview.hitTest(event).then(function(response) {
if (response.results.length) {
const graphic = response.results.filter(function (result) {
// check if the graphic belongs to the layer of interest
return result.graphic.layer.uid === kmlLayer.uid;
})[0].graphic;
const attributes = graphic.attributes;
mapview.popup.content = `
<b>${attributes.Name}</b>
<br/>
${attributes.Description}
<br/>
Custom content goes here
mapview.popup.open({
title: "Custom Popup Title",
Any sample code or knowledge on whether this is possible would be be appreciated.
