I'm trying to publish Trace as a web tool to utilize the WAB Network Trace widget.
The Trace tool will run successfully when using the feature service, but when trying to publish the geoprocessing tool it says that the "Data source used by the Task Trace is not registered with the server and will be copied to the server: ". I don't want it copied twice as its already a feature service?
If I use the sde feature class directly the error is "ERROR 002137: This operation is not supported in client-server mode."
Can someone provide some direction on what I'm not doing correctly or another approach that they have successfully configured?
All help is appreciated.
Regards,
Elliott
