I've been trying to make use of value list in the code below.
The issue is that the focus rectangle still display around an item when it gets deselected.
<html>
<head>
<meta charset="utf-8" />
<meta name="viewport" content="initial-scale=1,maximum-scale=1,user-scalable=no"/>
<title>V1 - Workaround : Deselecting a value list item</title>
<script src="https://js.arcgis.com/4.25/"></script>
<link rel="stylesheet" href="https://js.arcgis.com/4.25/esri/themes/light/main.css"/>
<script type="module" src="https://js.arcgis.com/calcite-components/1.0.0-beta.99/calcite.esm.js"></script>
<link rel="stylesheet" type="text/css" href=https://js.arcgis.com/calcite-components/1.0.0-beta.99/calcite.css />
</head>
<body>
<calcite-shell class="calcite-tutorial">
<calcite-shell-panel slot="panel-end">
<calcite-panel heading="Point list">
<calcite-value-list id="point-list">
<calcite-value-list-item label="point 1" value="point_1" description="NOT Selected"></calcite-value-list-item>
<calcite-value-list-item label="point 2" value="point_2" description="NOT Selected"></calcite-value-list-item>
<calcite-value-list-item label="point 3" value="point_3" description="NOT Selected"></calcite-value-list-item>
</calcite-value-list>
</calcite-panel>
</calcite-shell-panel>
</calcite-shell>
<script>
"use strict";
const listNode = document.getElementById("point-list")
// Cannot use the event listener below because nothing's fired when already-selected item is clicked
//listNode.addEventListener("calciteListChange", onListClickHandler)
listNode.addEventListener("click", onListClickHandler)
const currentSelectedListItem = (function(){
let currentItemValue
return {
is_same: function(selectedItemValue) {
if (currentItemValue != selectedItemValue) {
currentItemValue = selectedItemValue
return false
else {
return true
reset: function() {
currentItemValue = null
function onListClickHandler(event) {
const target = event.target
const targetId = target.value
if (currentSelectedListItem.is_same(targetId)) {
console.log("already selected")
target.selected = false;
currentSelectedListItem.reset();
// Do some stuff on map
// Test 1 (FAILS)
//target.toggleSelected()
// Test 2 (FAILS)
//target.removeAttribute("selected")
// Test 4 (FAILS)
//Array.from(listNode.childNodes).forEach(item => item.selected = false)
// Test 5 (FAILS)
//const listItems = listNode.querySelectorAll("calcite-value-list-item")
//listItems.forEach(item => item.selected = false)
else {
console.log("new selection")
// Debug test : updating the descriptions to show the selected state of each list item.
for(let listItem of event.target.parentElement.children) {
listItem.description = listItem.selected ? "Selected" : "NOT Selected";
//console.log(event.target.parentElement.children)
</script>
</body>
</html>
Could you help me please ?
