I'm trying to create different attribute rules for standalone tables in the first place. Therefore, I need to define rules that verify if a field is filled correctly.
For example: If field A is filled, field B must be filled too.
The first issue I'm facing is the fact that such a constraint rule is working fine, but after the constraint rule pops up, all fields are reset. As far as I know, there is no way to prevent the resetting of fields?
Due to this circumstance, my idea is to use validation rules. So, after the fields of a row within the standalone table are filled, the validation rule checks for missing fields/inputs. But here, the next problem occurs: I can't add an error layer for the standalone table (greyed out). I think it's only available for feature classes.
Do I miss something, or is there no way to solve my task using attribute rules regarding this topic?
I hope someone can help me,
best reagards
