Hi there,
My ArcGIS Pro 3.1 keep crashing when I get to a certain point of using the Suitability Modeler. I am able to set the criteria, but once I try to set the suitability value on a 32 bit raster (slope map) the application fails.
The interesting thing is that when I try to set the suitability value on the other two rasters (8 bit unsigned) the application runs fine.
I can't downsize the slope map to an 8bit unsigned because i need the float values. I am currently rebuilding pyramids to see if that helps anything.
Anyone have any other suggestions as to what I can do so that ArcGIS Pro stops crashing?
