My workflow is to have a link in Field Maps open up to the Survey123 field app. The field app is preferred due to low connectivity and having drafts just in case.
I have used both the argis-survey123:// prefix and the one listed on the website https://survey123.arcgis.app/ and both result in a constant cycle between "Downloading", "Unpacking", and "Downloading thumbnail" and will not open the form.
It is a survey that has URL parameters set to autopopulate fields within the feature layer and the survey also includes repeat questions. If I take out the URL parameters, survey opens up but the fields do not populate. If I include just GlobalID parameter, it will not open and blinks through the cycle.
Is there something wrong with my URL link or something I am missing?
Example:
https://survey123.arcgis.app/?itemID={ITEMID}?field:parentglobalID={GlobalID}&field:TYPE={TYPE}&field:ID={BMP_ID}&field:ASSET_ID={ASSET_ID}
