I have a hosted feature layer that I overwrite from a database export to csv regularly. It currently has 10 fields. I want to add an 11th field to the hosted feature service and adjust my csv export to include the 11th field. The workflow I tried to use is:
1. Manually add, via Data tab, an 11th field to the hosted feature service named "Billable" (String)
2. Update the database export to include the 11th field also named "Billable"
3. Use the "Update Data" - "Overwrite entire feature layer".
My hope was that by adding the field to the hosted feature layer, ensuring the same name, the overwrite functionality would simply overwrite the data and append the additional data for the new field.
The reality is that after the update, the 11th field that I manually created disappears so that my feature layer goes back to just having 10 fields.
Before I have to rework the entire creation of the feature layer and remap everything to point at the new feature layer I want to check with you guys as to whether its possible to add a new persistent field that won't dissapear whenever I do an "Update Data" action?
