Please create a geodatabase/arcpy tool that returns permissions on an input enterprise dataset. There are cases when we have new staff start and they need/want the same permissions as another user. It would be nice to be able to iterate over datasets in a geodatabase, get the permissions on a particular dataset and be able to check what permissions a certain user has. In this example, I could set a target user name and if found, assign the new user the same permissions as the target user.
The return could be something like either of the following:
return = [{user: UserName1, edit: True, view: True}, {user: UserName2, edit: False, view: True}]
return = [{user: UserName1, select: True, insert: True, update: True, delete: True}, {user: UserName2, select: True, insert: False, update: False, delete: False}]
