I have published a layer using ArcGIS Pro to the ArcGIS Server, and I subsequently built an application that uses this Feature layer to display data.
However, I've encountered an issue. When I set the symbology to 'Hatch fill' in combination with 'Solid fill', only the 'Hatch fill' style appears to be applied - the 'Solid fill' isn't having any effect.
Interestingly, when I test this with MapImageLayer, it works as expected. However, the requirement for my application is to use the Feature layer.
Any assistance or insights you could provide in resolving this issue would be greatly appreciated.
Best Regards
