I have map and survey widgets within a page and data is being sent from the map to the survey (created in Survey123 Connect). It has been working without issue until this morning.
When first opening the page, you can see the survey and it looks normal. As soon as you click on the shared feature, the form disappears and the following message appears: "only support esri geometry / geojson / xlsForm geometry". I saved the XLS from the original form, deleted it, created a new one with both the same name and an alternative name and neither new form provided different results. The only thing shared by both forms were the fields within the form. I am receiving these results in two separate Experiences, forms, and features.
Does anyone have any insight as to what could be causing this error?
