I'm getting started with ArcObject and i'm trying to build a console application that reads mdb file and shows it's contents but i have been working in it for a long time and i don't know what is the problem that i'm facing i'm using -windows server 2008 sp2 -VS 2010 C# -ArcGis 10.0 licence Type:ArcInfo-ArcSDK 10My code is as following
using System;
using System.Collections.Generic;
using System.Text;
using ESRI.ArcGIS.esriSystem;
using ESRI.ArcGIS.Geodatabase;
namespace DesktopConsoleApplication1
class Program
[STAThread()]
static void Main(string[] args)
IWorkspace iws;
iws = AccessWorkspaceFromPath(@C:\GD\Test.mdb);
public static IWorkspace AccessWorkspaceFromPath(String path)
//ESRI.ArcGIS.RuntimeManager.Bind(ESRI.ArcGIS.ProductCode.Desktop);
IWorkspaceFactory workspaceFactory = new ESRI.ArcGIS.DataSourcesFile.ArcInfoWorkspaceFactoryClass();
// Get FeatureClass to be set as datasource
IWorkspace workspace = workspaceFactory.OpenFromFile(path, 0);
return workspace;
when i us this code it give this error :Retrieving the COM class factory for component with CLSID {1D887452-D9F2-11D1-AA81-00C04FA33A15} failed due to the following error: 80040111.and when activating this line ESRI.ArcGIS.RuntimeManager.Bind(ESRI.ArcGIS.ProductCode.Desktop);it gives me this error :Error HRESULT E_FAIL has been returned from a call to a COM component.Please any one can help me to solve this problem.Thank you.
