I'm trying to do the basic example of creating a geoprocessing module found at https://pro.arcgis.com/en/pro-app/latest/arcpy/geoprocessing_and_python/extending-geoprocessing-through-python-modules.htm. I have a similar directory structure as in the example, up to the step where it says to run `arcpy.gp.createtoolboxsupportfiles()`. Thus, I don't have the `esri` folder yet. When I try to run the arcpy function, I get an error saying it cannot open the toolbox file.
python -c "import arcpy; arcpy.gp.createtoolboxsupportfiles(r'D:\misc_proj\arcgis\pkg_template\Src\ROOT\SampleToolbox.pyt')"
File "<string>", line 1, in <module>
File "C:\Program Files\ArcGIS\Pro\Resources\ArcPy\arcpy\geoprocessing\_base.py", line 512, in <lambda>
return lambda *args: val(*gp_fixargs(args, True))
RuntimeError: Cannot open D:\misc_proj\arcgis\pkg_template\Src\ROOT\SampleToolbox.pytThe file is definitely there, and definitely readable.
Any help about the error is appreciated. Thanks.
