I'm trying to create a GeoPackage that contains a raster image using .NET and C#. I was able to do something similar in Python but can't seem to get it to work in C#. Here's the simplified code:
private Task BuildExport ()
string output = @"C:\Data\GeoPackage.gpkg";
return QueuedTask.Run(() =>
if (SelectedMapFeatures == null) return;
try
var parameters = Geoprocessing.MakeValueArray(output, "GEOPACKAGE");
var result = Geoprocessing.ExecuteToolAsync("management.CreateSQLiteDatabase", parameters, null, null, null, GPExecuteToolFlags.None);
foreach (var map in SelectedMapFeatures)
foreach (var feature in map.Value)
parameters = Geoprocessing.MakeValueArray(feature.Raster, output, feature.Name, "Tiled", null);
result = Geoprocessing.ExecuteToolAsync("conversion.AddRasterToGeoPackage", parameters, null, null, null, GPExecuteToolFlags.None);
catch (Exception ex)
Debug.WriteLine(ex.ToString(), Assembly.GetExecutingAssembly().FullName);
}The GeoPackage is created just fine but adding the raster fails. An exception is thrown on line 18 of the MakeValueArray for the first parameter:
TAKInterface, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null: System.InvalidOperationException: convert unsupported type
at ArcGIS.Desktop.GeoProcessing.ObjectToValueConverter.to_string(CoreObjectsBase b, Object& oref)
at ArcGIS.Desktop.GeoProcessing.ObjectToValueConverter.ToString(Object o, Object& oref)
at ArcGIS.Desktop.Core.Geoprocessing.Geoprocessing.MakeValueArray(Object[] args)
at TAKInterface.TAKExporterDockPaneViewModel.<>c__DisplayClass26_0.<BuildExport>b__0() in C:\Users\...
The type for feature.Raster is RasterValue. I've tried using feature.Raster.GetRasterDataset() with the same error.
So, the question I have, is how do I get my raster into my GeoPackage?
