# Situation
- When building with the simulator
- When built from Xcode, it can load.
- When the app is launched from the home screen, it cannot be loaded.
- When building with the device
# Device info
- iPad Pro (11-inch) 2gen
- iPad OS (15.0.1)
- Xcode 14.1
# Library info
- arcgis-runtime-ios (100.15.2)
# App stracture
This application uses a multi-module structure.
- ArcGISAppKit // install arcgis-runtime-ios here
- ArcGISApp
- Pods
ArcGISAppKit/Package.swift
import PackageDescription
let package = Package(
platforms: [
.iOS(.v15)
products: [
// Products define the executables and libraries a package produces, and make them visible to other packages.
.library(
targets: ["ArcGISAppKit"]),
dependencies: [
.package(url: "https://github.com/esri/arcgis-runtime-ios", from: "100.15.2"),
.package(url: "https://github.com/Esri/arcgis-runtime-toolkit-ios", from: "100.15.0"),
targets: [
.target(
dependencies: [
.product(name: "ArcGIS", package: "arcgis-runtime-ios"),
.product(name: "ArcGISToolkit", package: "arcgis-runtime-toolkit-ios"),
.testTarget(
dependencies: ["ArcGISAppKit"]
# Affected code
// Called when ViewController is initialized
func load(mapPackage: AGSMobileMapPackage) async throws -> [AGSLayer] {
try await mapPackage.load() // an error occurs bud this method throws nothing
guard mapPackage.loadStatus == .loaded else {
throw .loadStatusError
guard let mobileMap = mapPackage.maps.first,
let layers = mobileMap.operationalLayers as? [AGSLayer] else {
throw .noDataError
mobileMap.operationalLayers.removeAllObjects()
let groupLayers = layers.compactMap { $0 as? AGSGroupLayer }
let featureLayers = layers.compactMap { $0 as? AGSFeatureLayer }
try await groupLayers.asyncForEach { layer in
try await layer.load()
try await featureLayers.asyncForEach { layer in
switch layer.name {
case "DestinationPoint":
let result = try await layer.featureTable?.queryFeatures(with: AGSQueryParameters())
destinationPointLocationList += result?.featureEnumerator().allObjects.compactMap(\.geometry?.extent.center) ?? []
default:
break
return groupLayers + featureLayers
# Errors output to console
2023-05-31 16:51:06.425313+0900 ArcGISApp[14607:3618492] Metal API Validation Enabled
2023-05-31 16:51:06.947983+0900 ArcGISApp[14607:3618492] ArcGIS Runtime Error Occurred. Set a breakpoint on C++ exceptions to see the original callstack and context for this error: Error Domain=com.esri.arcgis.runtime.error Code=18 "Internal error." UserInfo={NSLocalizedFailureReason=Could not load Metal shader library from '/private/var/containers/Bundle/Application/93F38F17-7CA9-49ED-BA26-6AD3AB71015A/ArcGISApp.app/Frameworks/ArcGIS.framework/shaders/re_texture_draw_vs.metallib'. Message: library not found, NSLocalizedDescription=Internal error., Additional Message=Could not load Metal shader library from '/private/var/containers/Bundle/Application/93F38F17-7CA9-49ED-BA26-6AD3AB71015A/ArcGISApp.app/Frameworks/ArcGIS.framework/shaders/re_texture_draw_vs.metallib'. Message: library not found}
2023-05-31 16:53:27.197459+0900 ArcGISApp[14607:3618602] XPC connection interrupted
