Hello All!
I'm currently working on a mitigation project and I've hit a few speedbumps. I'm using ArcGIS Pro Suitability Modeler to identify areas most at-risk for post-fire debris flow flooding using a variety of data (Primary/Secondary/Local Roads (lines), agricultural waterways (lines), hydrologic soils (polygons), burn scar basins (polygons), flow segments (lines), and basin outlets (points).
I've processed all data in the way I want it as rasters, gave them associated values, and imported them into the Suitability Parameters tab with the weighting I want, and the transforms come out exactly how I want them.
The Issue:
When I try to run the suitability at full resolution, the output suitability raster will come out with raster values of 0 to 0 with an area of interest raster value of NoData.
I've tried the following solutions to no joy:
- Turning it off and on again
- Creating a new suitability model with new transforms
- Adjusting transform / weighting values
- Decreasing the number of rasters being processed
Attached is an image showing the view (see HazardSuitability_map) in the top-left and in the symbology pane.
Anyone have any thoughts / recommendations?
