Using AGOL I created a map with one editable layer and then opened the map in Field Maps Designer. I created a very extensive form with many fields, groups, conditional visibility, etc. Early on I was able to save the form periodically to the map and the layer, but as I progressed both options were grayed out. I need to save the entire final form to the map and the layer to be able to use it in the field.
What am I doing wrong or overlooking? Is there some limit to the number of times a form can be saved or how large a form can be saved.
Thanks for any help you can give me.
Dan
