Not for a lack of searching, think I'm not getting results because I don't know the nomenclature.
I'm hoping to constrain the responses to a question, to ONLY the Select_One values.... Issue I'm getting is that after the user selects one, they can still add/edit the value populated.
Is there a parameter column and code I can use to lock the response to ONLY the select_one values available?
