I'm teaching GIS in a university environment to students who use ArcGIS Pro and have access to a large amount of local storage. I had hoped they could use the Living Atlas Terrain layer as a source within Pro to obtain a DEM for an country of their choice, for further processing using Spatial Analyst and integration with other locally-stored data. They already have access to a polygon covering their chosen country for masking purposes.
The Terrain layer I mean, for clarity, is: https://www.arcgis.com/home/item.html?id=58a541efc59545e6b7137f961d7de883
The layer information states that "For analyses using ArcGIS Desktop, you can filter a dataset, specify the projection, extent and cell size using the Make Image Server Layer geoprocessing tool."
We have found that there is a limit to this process (with this layer), of 5000 rows x 5000 columns. Is there an alternative workflow to be able to obtain a larger dataset from this layer for analysis? Currently we have decided to download tiles from CGIAR and mosaic/extract for the desired country, but I wanted to check I am not missing a more seamless solution from Living Atlas.
It would also be useful to state this limitation clearly on the layer description.
