I want to join these two blue polygon attributes to the pink line. If you run the intersection tool, only the attributes from the two blue polygons will get applied to the line fragments, as expected since the pink line doesn't cross the boundary of the third polygon.
But when you do a spatial join or spatial selection with the "Intersect" option, suddenly it grabs the third polygon.
There are easy workarounds if you just doing a selection. But if you are doing a join, it's not so easy. You can't really choose multiple spatial relationships with a join (i.e. "Within OR Crosses Boundary").
I can't use the Intersect tool, because I don't want the lines to get split, and when I try to dissolve them back to the original line shapes the attributes from the polygons get messed up. (The dissolve tool does weird things with attribute aggregation.)
Does anyone else have this issue?
I will probably do multiple joins then figure out how to combine fields, but it seems like it should be much easier than that. This is the type of join I use most often.
