I was wondering if anyone could help me with a question related to ArcGIS Online/ArcGIS Field Maps.
I work at a Nature Reserve. Specifically I am having issues with the ability to collect data in the field using ArcGIS Field Maps. We are located in an area without a reliable network, so I designed an offline map area in ArcGIS Field Maps Designer. The issue is that when in the field, using the offline map, we cannot edit the form/collect data at our points.
As you can see in the attached images, in the online version, we can click Edit and collect data. In the offline version, the edit button is not there in the bottom bar.
Any help or insight is appreciated.
I will add that when I create the offline area through the app, I am able to edit. But I'd rather create it in Field Maps Designer for simplicity.
