I have a project to extract 3D buildings from LiDAR for a municipality. I have been following two workflows; the 3D Basemaps Solution, as well as the tutorial called "Extract 3D Buildings from LiDAR Data". Following the 3D Basemaps Solution, and applying procedural symbology and a rule package to the layer, I have found good results for small, simple buildings like single and multi family homes with simpler roof forms. However, it is challenging to find good results with complex buildings such as towers with attached pools, skylights, and unique roof forms.
Are there any suggestions on using the 3D Basemaps Solution to generate complex towers accurately?
Conversely, the buildings which I generate from the LAS Building Multipatch tool are accurate in shape, but the roof forms appear jagged and sharp, especially on edges. I have tried techniques like resampling, thinning the las dataset, and adjusting sampling/simplification values, but end up with poor results.
I have attached screenshots for context, all suggestions are welcome.
