I am looking to simplify my code. As of right now I have a code that allows the users to extract GIS data in three different ways. 1) Extract by Drawn extent, 2) Extract by extent of the a county, 3) Extract by Extent by Unit.1st function: function extractData() { //get clip layers var clipLayers = []; if (registry.byId("layer1").get("checked")) { clipLayers.push("SRA"); } if (registry.byId("layer2").get("checked")) { clipLayers.push("Burn"); } if (clipLayers.length === 0|| map.graphics.graphics.length === 0) { alert("Select layers to extract and draw an area of interest."); return; } var featureSet = new FeatureSet(); var features = []; features.push(map.graphics.graphics[0]); featureSet.features = features; var params3 = { "Layers_to_Clip": clipLayers, "Area_of_Interest": featureSet, "Feature_Format": registry.byId("formatBox").get("value") }; domStyle.set(loading2, "display", "inline-block"); gp.submitJob(params3, completeCallback, statusCallback2, function (error) { alert(error); domStyle.set(loading2, "display", "none"); }); }2nd fucntion: function executeQueryTask(county) { var clipLayers = []; if (registry.byId("layer1").get("checked")) { clipLayers.push("SRA"); } if (registry.byId("layer2").get("checked")) { clipLayers.push("Burn"); } if (clipLayers.length === 0) { alert("No layers to clip, please select a layer you would like to clip..."); return; } var county = document.getElementById("sel_county").value var queryTask = new QueryTask("http://webgisdevint1/arcgis/rest/services/Alex_Try/Counties/MapServer/0"); queryTask.on("complete", addToMap) var query = new Query(); query.returnGeometry = true; query.outFields = ["NAME_PCASE"]; query.where = "NAME_PCASE = '" + county + "'"; query.outSpatialReference = map.spatialReference; queryTask.execute(query, function (featureSet) { var AOI = featureSet.features[0].geometry; var graphic = new Graphic(AOI, symbol); var features = []; features.push(graphic); var fSet = new FeatureSet(); fSet.features = features; var params = { "Layers_to_Clip": clipLayers, "Area_of_Interest": fSet, "Feature_Format": registry.byId("formatBox").get("value") }; domStyle.set(loading, "display", "inline-block"); gp.submitJob(params, completeCallback, statusCallback, function (error) { alert(error); domStyle.set(loading, "display", "none"); }); }); }And a third that looks exactly like the one above except that I query by units not county.Each function is triggered by this: registry.byId("extract1").on("click", executeQueryTask);And this: <button id="extract1" data-dojo-type="dijit/form/Button" data-dojo-props="iconClass:'Query', showLabel:false"> Extract Data </button>
Now here is my question: How can independently trigger each function from ONE AND ONLY ONE button? As of right now I have three buttons that triggers each function. Would it be possible to trigger each function independently from only 1 button? For example, If users draw then the 1 and only "extract" button would extract data by the extent drawn by the user. FYI I am using a dijit/from/dropdown for selecting counties and units, which means there always be one element selected in these two extraction process.Thank you,Alex
