ArcGIS Pro 3.1.1
In the Catalog pane —> Database connection —> Properties —> Name:
The Name textbox appears to be an editable textbox.
However, in reality the textbox isn't editable.
Video:
That seems misleading.
Could that textbox be changed? For example, one of the following:
- Use the textbox to rename the database connection.
- Grey-out the textbox.
- Convert the text box to a label.
Edit: Regardless of what option Esri goes with, the text should still be copyable, since it's handy to copy the connection location.
I'm aware that I can rename the database connection directly in Catalog. That works. But I think the point is the properties Name textbox is somewhat unintuitive and could be improved.
Thanks.
