A bug in the JavaScript Maps SDK causes features to be labeled improperly when the field from which labels are derived has a range domain (i.e. RangeDomain). Rather than the field's value being displayed, the field's domain name is displayed instead, as shown below:
Displayed above is the Create a FeatureLayer with client-side graphics sample with some modifications that cause the issue to be seen. This can be reproduced by replacing the contents of the third script tag with the code below (a simple diff utility can show the changes):
require([
"esri/Map",
"esri/views/MapView",
"esri/layers/FeatureLayer",
"esri/layers/support/LabelClass",
"esri/layers/support/RangeDomain",
"esri/core/promiseUtils",
"esri/Graphic",
"esri/geometry/Point",
"esri/rest/locator"
Map,
MapView,
FeatureLayer,
LabelClass,
RangeDomain,
promiseUtils,
Graphic,
Point,
locator
var labelIndex = 1;
const view = new MapView({
map: new Map({
basemap: "gray-vector"
container: "viewDiv",
extent: {
spatialReference: {
wkid: 102100
xmin: -14488954,
ymin: 3457304,
xmax: -10656095,
ymax: 5250211
popup: {
dockEnabled: true,
dockOptions: {
position: "top-right",
breakpoint: false
view
.when()
.then(fetchImages)
.then(getFeaturesFromPromises)
.then(createLayer)
.then(addToView)
.catch((e) => {
console.error("Creating FeatureLayer from photos failed", e);
* Fetches a list of images and returns a list of promises
function fetchImages() {
const numPhotos = 18;
const graphicPromises = [];
const baseUrl =
"https://arcgis.github.io/arcgis-samples-javascript/sample-data/featurelayer-collection/photo-";
for (let i = 1; i <= numPhotos; i++) {
const url = baseUrl + i.toString() + ".jpg";
const graphicPromise = exifToGraphic(url, i);
graphicPromises.push(graphicPromise);
return promiseUtils.eachAlways(graphicPromises);
// Filters only promises that resolve with valid values (a graphic
// in this case) and resolves them as an array of graphics.
// In other words, each attempt at fetching an image returns a promise.
// Images that fail to fetch will be filtered out of the response array
// so the images that successfully load can be added to the layer.
function getFeaturesFromPromises(eachAlwaysResponses) {
return eachAlwaysResponses
.filter((graphicPromise) => {
return graphicPromise.value;
.map((graphicPromise) => {
// Creates a client-side FeatureLayer from an array of graphics
function createLayer(graphics) {
return new FeatureLayer({
source: graphics,
objectIdField: "OBJECTID",
fields: [
type: "oid"
type: "string"
type: "integer",
domain: RangeDomain.fromJSON({
type: "range",
range: [1,10000000]
labelingInfo: [
LabelClass.fromJSON({
"labelPlacement": "esriServerPolygonPlacementAlwaysHorizontal",
"where": null,
"labelExpression": "[labeltest]",
"useCodedValues": true,
"symbol": {
"type": "esriTS",
"color": [
230,
76,
0,
255
"backgroundColor": null,
"borderLineColor": null,
"borderLineSize": null,
"verticalAlignment": "bottom",
"horizontalAlignment": "left",
"rightToLeft": false,
"angle": 0,
"xoffset": 0,
"yoffset": 0,
"kerning": true,
"haloColor": [
255,
255,
255,
178
"haloSize": 1.25,
"font": {
"family": "Arial",
"size": 16,
"style": "normal",
"weight": "bold",
"decoration": "none"
"minScale": 0,
"maxScale": 0
popupTemplate: {
title: (event) => {
return locator
.locationToAddress({
.then((response) => {
return response.address;
.catch((error) => {
return "The middle of nowhere";
content: "<img src='{url}'>"
renderer: {
type: "simple",
symbol: {
type: "text",
color: "#7A003C",
text: "\ue661",
font: {
family: "CalciteWebCoreIcons"
// Adds a given layer to the map in the view
function addToView(layer) {
view.map.add(layer);
* Fetches and loads an image from a url and gets the latitude/longitude
* GPS data from the EXIF data of the image. Returns a promise that
* resolves to a Graphic with a point geometry representing the location
* where the photo was taken.
function exifToGraphic(url, id) {
return promiseUtils.create((resolve, reject) => {
const image = document.createElement("img");
image.src=url;
image.onload = () => {
image.load = image.onerror = null;
EXIF.getData(image, function () {
const latitude = EXIF.getTag(this, "GPSLatitude");
const latitudeDirection = EXIF.getTag(this, "GPSLatitudeRef");
const longitude = EXIF.getTag(this, "GPSLongitude");
const longitudeDirection = EXIF.getTag(this, "GPSLongitudeRef");
if (!latitude || !longitude) {
reject(
new Error(
"Photo doesn't contain GPS information: ",
this.src
return;
const location = new Point({
latitude: dmsDD(latitude, latitudeDirection),
longitude: dmsDD(longitude, longitudeDirection)
resolve(
new Graphic({
geometry: location,
attributes: {
url: url,
OBJECTID: id,
labeltest: labelIndex++
image.onerror = () => {
reject(new Error("Error while loading the image"));
// Converts a DMS coordinate to decimal degrees
function dmsDD([degrees, minutes, seconds], direction) {
let dd = degrees + minutes / 60 + seconds / 3600;
if (direction === "S" || direction === "W") {
dd *= -1;
return dd;
The problem occurs in the esri/layers/support/labelFormatUtils module - in particular, line 15 of the function below:
function t(b, f) {
if (null == b)
return "";
const a = f.domain;
if (a)
if ("codedValue" === a.type || "coded-value" === a.type)
for (var g of a.codedValues) {
if (g.code === b)
return g.name
else if ("range" === a.type) {
g = +b;
const h = "range"in a ? a.range[1] : a.maxValue;
if (("range"in a ? a.range[0] : a.minValue) <= g && g <= h)
return a.name
"date" === f.type || "esriFieldTypeDate" === f.type ? b = q.formatDate(b, q.convertDateFormatToIntlOptions("short-date")) : z.isNumericField(f) && (b = y.formatNumber(+b));
return b ? b : ""
As can be seen, if the value is within the range of the domain, the domain's name is returned. This issue can be fixed by replacing "return a.name" with "return b". The code shown above is from version 4.26, but the problem goes at least as far back as 4.23.
