I am creating a custom widget for ExB that is based on the filter widget. I'd like to modify the data source (feature layer) used for the filtering and change its renderer, specifically set it to a class breaks renderer with breaks depending on what filtered values they selected. I was able to create the renderer object but when I try to set the FeatureLayer.renderer = render, nothing happens. I assume that is because ExB is getting the renderer from the web map still. I was thinking maybe having to use LayerView but don't see a renderer property on it. Any ideas?
