As an organization, we accept many types of plans from Surveyors. This includes posting plans, which contain parcel boundary linework but no related parcels. We use a digital submission process that creates simple feature class that represent survey plan information. The resulting line feature class that is created from the digital submission process is brought into the parcel fabric using the ‘Copy Lines To’ tool.
This is the most efficient way to bring in the geometry and attributes of the lines into the parcel fabric; however, the ‘Copy Lines To’ tool automatically creates seeds for each closed loop. In the case of the posting plans we work with, we do not need parcel seeds built for each closed loop of lines. This means that once the lines are copied into the parcel fabric and the seeds are created, the seeds need to be selected and deleted. This can be a tedious process.
We would like to be able to have the option to decide whether the ‘Copy Lines To’ tool creates seeds or not. This could look like a radio button that you can enable if you would like to create seeds when the tool is executed or disabled if you do not need to create seeds for the linework you are bringing in. This would streamline our workflow and save us time in the long run.
Example of a posting plan is attached, note there is no parcels created with this plan only lines.
