Hello. I am fairly new to Power Automate and its capabilities. I am trying to set up a flow where an Excel sheet in Sharepoint will update with a record when a field in a feature class is changed to a certain value. 'When a record is updated in a feature layer' seems to be the correct initial process. However, I'm having trouble figuring out how to correctly set up the trigger to where the flow only initiates when a certain field gets to a certain value.
Then I picked 'Add a row into a table' Excel tool. However, when I get to this portion, for some reason, the 'table' field shows no values. I have no issues navigating to the Excel sheet, but for whatever reason, that 'table' field will not populate.
Does anyone have experience setting up a process like this? I looked on the Microsoft help site and there isn't a whole lot of beginner level information from what I could find.
Thanks!
