I'm using experience builder to allow a user to select a point in a map and complete a survey for that feature. In Survey123 web designer I have set up a a type question that uses a calculation to grab a value from the attribute table. This value uses coded domains. Is it possible to return the description in the survey rather than the code? i.e. when a red point is selected Type returns 1, not red.
