I'm really liking the new SwiftUI implementation but I'm having trouble with one thing. I have a button to zoom to the current location. In order to do that I set a viewpoint and it works the first time. But if I move and try to tap it again it doesn't zoom. The workaround is I watch the viewpoint for changes and set it back to nil immediately. Is this the best way to implement zooming or is there some other way to do it? I can't find anything in the docs for it. Here's the example code:
struct MapZoomTestView: View {
@StateObject private var map: Map = {
let map = Map(basemapStyle: .arcGISTopographic)
map.initialViewpoint = Viewpoint(latitude: 34.02700, longitude: -118.80500, scale: 72_000)
return map
@State var viewpoint: Viewpoint? = nil
let locationDisplay = LocationDisplay(dataSource: SystemLocationDataSource())
init() {
ArcGISEnvironment.apiKey = APIKey("")
var body: some View {
MapView(map: map, viewpoint: viewpoint)
.locationDisplay(locationDisplay)
.task {
let locationManager = CLLocationManager()
if locationManager.authorizationStatus == .notDetermined {
locationManager.requestWhenInUseAuthorization()
do {
try await locationDisplay.dataSource.start()
} catch {
print("Current Location Cannot Be Shown")
.overlay(alignment: .bottomLeading) {
Button {
guard let location = locationDisplay.location else {
return
viewpoint = Viewpoint(center: location.position, scale: 10_000)
} label: {
Image(systemName: "paperplane.fill")
.frame(width: 50, height: 50, alignment: .center)
.background(.regularMaterial)
.cornerRadius(25.0)
.padding([.leading, .bottom])
.onChange(of: viewpoint) { newValue in
guard newValue != nil else {
return
viewpoint = nil
.ignoresSafeArea()
