When working with database tables in ArcGIS Pro the processing seems pretty slow. I believe the culprits are the cursors (search, update, insert) and I would like to walk away from using those.
So I was wondering if I can simply switch to SQL in e.g. SQL Server Management Studio, work there and return later to ArcGIS Pro, without destroying something. By 'destroying something' I mean stuff in the GDB_*, SDE_* and i* tables.
Is it possible to work with Enterprise SQL databases purely in SQL, and if so, are there limitations on what I cannot do?
Bests Thomas
