Hello, I'm trying to clone content from Portal A to Portal B through a clone. I'm writing to ask when the error occurred.
1. from arcgis.gis import GIS
2. gis1 = GIS("https://portal_a.esri.com/portal","contentownerID","contentownerPW") # source portal
3. gis2 = GIS("https://portal_b.esri.com/portal","receivedcontentownerID.","receivedcontentownerPW")
4. item = gis1.content.get('12cnje12ads')
# ''In between, there is a content ID.
5. data = [item]
6. gis2.content.clone_items(data,"test")
# "" In between, there is a Folder NameThe following error occurs when executing this code.
_ItemCreateException Traceback (most recent call last)
In [14]:
Line 1: gis2.content.clone_items(data,"clone")
File C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\arcgis\gis\__init__.py, in clone_items:
Line 7904: return deep_cloner.clone()
File C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\arcgis\_impl\common\_clone.py, in clone:
Line 1218: results = executor.submit(self._clone, executor).result()
File C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\concurrent\futures\_base.py, in result:
Line 446: return self.__get_result()
File C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\concurrent\futures\_base.py, in __get_result:
Line 391: raise self._exception
File C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\concurrent\futures\thread.py, in run:
Line 58: result = self.fn(*self.args, **self.kwargs)
File C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\arcgis\_impl\common\_clone.py, in _clone:
Line 1191: raise ex
Line 3874: raise _ItemCreateException(
_ItemCreateException: ("Failed to create Feature Service assignments_4ff1ca532bd946af845e5bd5a6b909c3: A connection error has occurred: HTTPSConnectionPool(host='gisserver.reprc.co.kr', port=443): Max retries exceeded with url: /server/rest/services/Hosted/assignments_bf1e4/FeatureServer (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x000001866A1CE700>: Failed to establish a new connection: [Errno 11001] getaddrinfo failed'))", <Item title:"assignments_bf1e4" type:Feature Layer Collection owner:portaladmin>)
I'm eagerly awaiting your help.
Thank you
from Jin-tae Kim, South-Korea Esri User.
