Hi all,
I have a field capture project where I have buildings that contains establishments (businesses or other occupiers). It is conducted every 5 years so there is existing data that is verified as well as new data that is captured. We have a 3 character string field called 'EstablishmentID' businesses use a range from '001' to '499'. The process when adding new businesses is to use the next available number in the range, but when we get to the next available being '500' we have to search from '001' and find the first available within the range.
I managed to do this, but it is not very sophisticated. Just wondering if there is a better way
// featureset filter to remove non business establishments
var business_establishments = filter(building_ests,"(ESTABLISHMENTID Not Like '5%%') and (ESTABLISHMENTID Not Like '6%%') and (ESTABLISHMENTID Not Like '7%%') and (ESTABLISHMENTID Not Like '9%%')")
// calculating next available EstablishmentID number
var next = number(max(business_establishments,'ESTABLISHMENTID')) + 1
// if next number is 500 then run loop
if(number(right(concatenate('00',Text(next)),3)) == 500){
// build array from 1 to 499
var id = 1
var ary =[]
while(id < 500){
push(ary,id)
id+=1
// loop through featureset and remove establishmentids that are in array
for(var e in rest_data){
erase(ary,indexof(ary,number(e.establishmentid)))
// next establishment id is taken from first value in modified array
var nextestid = right(concatenate('00',Text(first(ary))),3)
// if next number is less than 500 use original next variable
else{
var nextestid = right(concatenate('00',Text(next)),3)
