I find using the Feature info widget while wrapped inside the Sidebar to be superior to the traditional pop-up on top of the map as a method to display feature attributes. However one of the big limitations in the Experience Builder version I have found is that there is no "Clear Selection" button within the attribute display. The selection often needs to be cleared for any number of actions that may follow. The only option to clear the selection is to enable the select option on the map, which I find to be a poor implementation (looking forward to the stand-alone Select widget!), and will confusing for the user to look in a different place than the Feature attribute window. The Sidebar Instant App has a clear and simple method of clearing the feature selection from within the attribute display window. Please add a "Clear Selection" button to the attribute window of the Feature Info widget, similar to how it is implemented in the Sidebar Instant App.
