Hi. I am working with the Lead Service Line Inventory solution. I am having problems with the Survey123 component after making some modifications in Connect. I would like to download the original Survey123 item contained in the solution and simply start over. Is there a way to accomplish this? Can I deploy the same solution again and retrieve the Survey item, or will this redeploy overwrite everything in the original deployed solution? I don't know much about redeploying the same solution. I have populated the ServiceLine feature service and don't want to lose/overwrite the existing service layer and lose the data. Thanks, Jay
