Hello All,
I am updating a hosted feature layer due to potential corruption to the current Hosted feature layer. I downloaded the current feature layer to be corrected in Pro then hosted the new layer to AGOL. I added the new layer to the Web Map, saved the map and then I check to see if it automatically loaded it to the Web App Builder map. It did load it; however, it is not honoring the unique values symbology that was set in the web map (see attached video). I have created this layer multiple times from scratch, and each time it does not honor the unique values setting in the web map. Is this the result of the latest update to Map Viewer? I am using map viewer with the web app builder, this was working prior to the update, as you can in the video there are2 layers for the Maintenance Zones one ending with "Zone", the updated version, and the other ending with "Zones" the original version.
