Driver: GTiff/GeoTIFF
Files: Bolivia.tiff
Size is 7661, 7781
Warning 1: PROJ: proj_create_from_database: C:\OSGeo4W\share\proj\proj.db contains DATABASE.LAYOUT.VERSION.MINOR = 1 whereas a number >= 2 is expected. It comes from another PROJ installation.
Warning 1: The definition of projected CRS EPSG:32619 got from GeoTIFF keys is not the same as the one from the EPSG registry, which may cause issues during reprojection operations. Set GTIFF_SRS_SOURCE configuration option to EPSG to use official parameters (overriding the ones from GeoTIFF keys), or to GEOKEYS to use custom values from GeoTIFF keys and drop the EPSG code.
Warning 1: PROJ: proj_create_from_name: C:\OSGeo4W\share\proj\proj.db contains DATABASE.LAYOUT.VERSION.MINOR = 1 whereas a number >= 2 is expected. It comes from another PROJ installation.
Coordinate System is:
PROJCRS["WGS_1984_UTM_Zone_19N",
BASEGEOGCRS["WGS 84",
DATUM["World Geodetic System 1984",
ELLIPSOID["WGS 84",6378137,298.257223563,
LENGTHUNIT["metre",1,
ID["EPSG",9001]]]],
PRIMEM["Greenwich",0,
ANGLEUNIT["degree",0.0174532925199433,
ID["EPSG",9122]]]],
CONVERSION["Transverse Mercator",
METHOD["Transverse Mercator",
ID["EPSG",9807]],
PARAMETER["Latitude of natural origin",0,
ANGLEUNIT["degree",0.0174532925199433],
ID["EPSG",8801]],
PARAMETER["Longitude of natural origin",-69,
ID["EPSG",8802]],
PARAMETER["Scale factor at natural origin",0.9996,
SCALEUNIT["unity",1],
ID["EPSG",8805]],
PARAMETER["False easting",500000,
LENGTHUNIT["metre",1],
ID["EPSG",8806]],
PARAMETER["False northing",0,
ID["EPSG",8807]]],
CS[Cartesian,2],
AXIS["easting",east,
ORDER[1],
ID["EPSG",9001]]],
AXIS["northing",north,
ORDER[2],
ID["EPSG",9001]]]]
Data axis to CRS axis mapping: 1,2
Origin = (561885.000000000000000,-1322685.000000000000000)
Pixel Size = (30.000000000000000,-30.000000000000000)
Metadata:
AcquisitionDate=43655.607084074072
AREA_OR_POINT=Area
CloudCover=0.000000000000000000
DatasetTag=MS
DataType=Generic
ParentRasterType=Landsat 8
ParentTemplate=Multispectral
ProductName=L1TP
SensorName=Landsat 8
SunAzimuth=40.144335900000001516
SunElevation=43.934061520000000201
Image Structure Metadata:
COMPRESSION=LZW
INTERLEAVE=PIXEL
LAYOUT=COG
Corner Coordinates:
Upper Left ( 561885.000,-1322685.000) ( 68d25'53.74"W, 11d57'51.98"S)
Lower Left ( 561885.000,-1556115.000) ( 68d25'36.35"W, 14d 4'30.61"S)
Upper Right ( 791715.000,-1322685.000) ( 66d19'17.83"W, 11d57' 8.06"S)
Lower Right ( 791715.000,-1556115.000) ( 66d17'55.98"W, 14d 3'38.65"S)
Center ( 676800.000,-1439400.000) ( 67d22'11.01"W, 13d 0'55.27"S)
Band 1 Block=512x512 Type=UInt16, ColorInterp=Gray
Description = CoastalAerosol
Min=6131.000 Max=65535.000
Minimum=6131.000, Maximum=65535.000, Mean=8905.080, StdDev=177.506
NoData Value=0
Overviews: 3831x3891, 1916x1946, 958x973, 479x487, 240x244
Metadata:
BandName=CoastalAerosol
RadianceBias=-60.734389999999997656
RadianceGain=0.012147000000000000
ReflectanceBias=-0.100000000000000006
ReflectanceGain=0.000020000000000000
RepresentationType=ATHEMATIC
STATISTICS_COVARIANCES=31508.52665301626,41642.15679906171,60672.355627964,100761.9852593969,-195143.4491109666,118476.8275766652,108672.286833731,138.1712517149589
STATISTICS_MAXIMUM=65535
STATISTICS_MEAN=8905.0801598933
STATISTICS_MEDIAN=8693.525490
STATISTICS_MINIMUM=6131
STATISTICS_SKIPFACTORX=1
STATISTICS_SKIPFACTORY=1
STATISTICS_STDDEV=177.50641299124
WavelengthMax=450.000000000000000000
WavelengthMin=430.000000000000000000
Band 2 Block=512x512 Type=UInt16, ColorInterp=Undefined
Description = Blue
Min=6812.000 Max=35999.000
Minimum=6812.000, Maximum=35999.000, Mean=8069.279, StdDev=239.697
NoData Value=0
Metadata:
BandName=Blue
RadianceBias=-62.192759999999999820
RadianceGain=0.012439000000000000
STATISTICS_COVARIANCES=41642.15679906171,57454.85861445696,86149.47310466296,142884.8829616395,-281256.6995189103,163279.4277654528,149520.4595701488,191.5452585793981
STATISTICS_MAXIMUM=35999
STATISTICS_MEAN=8069.2794414995
STATISTICS_MEDIAN=7956.588235
STATISTICS_MINIMUM=6812
STATISTICS_STDDEV=239.69743138894
WavelengthMax=510.000000000000000000
WavelengthMin=450.000000000000000000
Band 3 Block=512x512 Type=UInt16, ColorInterp=Undefined
Description = Green
Min=6427.000 Max=20046.000
Minimum=6427.000, Maximum=20046.000, Mean=7461.374, StdDev=383.060
NoData Value=0
Metadata:
BandName=Green
RadianceBias=-57.310090000000002419
RadianceGain=0.011462000000000000
STATISTICS_COVARIANCES=60672.355627964,86149.47310466296,146735.1970440772,224919.4698553707,-339954.589094391,210672.3368468368,189659.0996540143,237.5565712845495
STATISTICS_MAXIMUM=20046
STATISTICS_MEAN=7461.3737144374
STATISTICS_MEDIAN=7334.933333
STATISTICS_MINIMUM=6427
STATISTICS_STDDEV=383.06030470942
WavelengthMax=590.000000000000000000
WavelengthMin=530.000000000000000000
Band 4 Block=512x512 Type=UInt16, ColorInterp=Undefined
Description = Red
Min=5566.000 Max=20382.000
Minimum=5566.000, Maximum=20382.000, Mean=6772.979, StdDev=623.572
NoData Value=0
Metadata:
BandName=Red
RadianceBias=-48.327100000000001501
RadianceGain=0.009665399999999999
STATISTICS_COVARIANCES=100761.9852593969,142884.8829616395,224919.4698553707,388841.5805853336,-789521.2702374764,414701.3373873618,380051.9154543081,522.6371678856232
STATISTICS_MAXIMUM=20382
STATISTICS_MEAN=6772.9790924259
STATISTICS_MEDIAN=6437.529412
STATISTICS_MINIMUM=5566
STATISTICS_STDDEV=623.57163228079
WavelengthMax=670.000000000000000000
WavelengthMin=640.000000000000000000
Band 5 Block=512x512 Type=UInt16, ColorInterp=Undefined
Description = NearInfrared
Min=4608.000 Max=32502.000
Minimum=4608.000, Maximum=32502.000, Mean=13995.801, StdDev=2071.420
NoData Value=0
Metadata:
BandName=NearInfrared
RadianceBias=-29.573779999999999291
RadianceGain=0.005914800000000000
STATISTICS_COVARIANCES=-195143.4491109666,-281256.6995189103,-339954.589094391,-789521.2702374764,4290781.202010791,-253487.4614312998,-716183.7034941466,-1185.24140439538
STATISTICS_MAXIMUM=32502
STATISTICS_MEAN=13995.80144226
STATISTICS_MEDIAN=14343.552941
STATISTICS_MINIMUM=4608
STATISTICS_STDDEV=2071.4200930788
WavelengthMax=880.000000000000000000
WavelengthMin=850.000000000000000000
Band 6 Block=512x512 Type=UInt16, ColorInterp=Undefined
Description = ShortWaveInfrared_1
Min=4649.000 Max=65535.000
Minimum=4649.000, Maximum=65535.000, Mean=10096.295, StdDev=1538.379
NoData Value=0
Metadata:
BandName=ShortWaveInfrared_1
RadianceBias=-7.354729999999999990
RadianceGain=0.001470900000000000
STATISTICS_COVARIANCES=118476.8275766652,163279.4277654528,210672.3368468368,414701.3373873618,-253487.4614312998,2366608.875233505,1474145.926775633,2391.277470791071
STATISTICS_MEAN=10096.294938413
STATISTICS_MEDIAN=9424.372549
STATISTICS_MINIMUM=4649
STATISTICS_STDDEV=1538.3786514488
WavelengthMax=1650.000000000000000000
WavelengthMin=1570.000000000000000000
Band 7 Block=512x512 Type=UInt16, ColorInterp=Undefined
Description = ShortWaveInfrared_2
Min=4257.000 Max=65535.000
Minimum=4257.000, Maximum=65535.000, Mean=7163.728, StdDev=1030.534
NoData Value=0
Metadata:
BandName=ShortWaveInfrared_2
RadianceBias=-2.478940000000000143
RadianceGain=0.000495790000000000
STATISTICS_COVARIANCES=108672.286833731,149520.4595701488,189659.0996540143,380051.9154543081,-716183.7034941466,1474145.926775633,1062000.165344211,1592.500852970767
STATISTICS_MEAN=7163.7281692793
STATISTICS_MEDIAN=6660.058824
STATISTICS_MINIMUM=4257
STATISTICS_STDDEV=1030.5339224617
WavelengthMax=2290.000000000000000000
WavelengthMin=2110.000000000000000000
Band 8 Block=512x512 Type=UInt16, ColorInterp=Undefined
Description = Cirrus
Min=4372.000 Max=13262.000
Minimum=4372.000, Maximum=13262.000, Mean=5033.905, StdDev=10.463
NoData Value=0
Metadata:
BandName=Cirrus
RadianceBias=-11.558099999999999596
RadianceGain=0.002311600000000000
STATISTICS_COVARIANCES=138.1712517149589,191.5452585793981,237.5565712845495,522.6371678856232,-1185.24140439538,2391.277470791071,1592.500852970767,109.4827697063441
STATISTICS_MAXIMUM=13262
STATISTICS_MEAN=5033.9045103191
STATISTICS_MEDIAN=4999.529412
STATISTICS_MINIMUM=4372
STATISTICS_STDDEV=10.463401440561
WavelengthMax=1380.000000000000000000
WavelengthMin=1360.000000000000000000
