Hello there,
I've been using the ArcGIS package on my computer using the conda package installations with no problems. However, I needed better computing abilities to train the model faster. So I tried to install the ArcGIS on the graham cluster from Compute Canada which only allows pip installations, and it is prohibited to use conda.
I used the pip install arcgis==2.1.0.2 to install the library as specified in the installation instructions and there were no problems.
However, when I try to use the prepare_data function on my exported point cloud data I get the following error:
" /home/aziz99/ENV/lib/python3.8/site-packages/arcgis/learn/models/_arcgis_model.py:459: UserWarning: Cuda is not available
warnings.warn("Cuda is not available")
File "<stdin>", line 1, in <module>
File "/home/aziz99/ENV/lib/python3.8/site-packages/arcgis/learn/_data.py", line 2687, in prepare_data
data = pointcloud_prepare_data(
File "/home/aziz99/ENV/lib/python3.8/site-packages/arcgis/learn/_utils/pointcloud_data.py", line 1845, in pointcloud_prepare_data
src=PointCloudItemList.from_folder(
AttributeError: type object 'PointCloudItemList' has no attribute 'from_folder'"
I am pretty sure that there is nothing wrong with the data as it works normally when I use the prepare_data on the conda environment.
I really appreciate your help,
Thank you in advance
