I'm using Esri.ArcGISRuntime.Maui v200.0.0. Admittedly I am new to using Esri so maybe there is a more obvious solution: I am wanting to dynamically add and remove site pins on the map. First attempt was to reuse the initial set of Graphic objects and just build a new GraphicsOverlay and only add the Graphics desired. Then null out the GraphicsOverlays collection and add a new one. This resulted in the Object Already Owned exception.
Second attempt is to create a new GraphicsOverlay along with a new Graphic object for each item and add it to the GraphicsOverlays collection. Removing a GraphicOverlay is as simple as identifying the particular GraphicOverlay and removing it from the GraphicOverlays collection. In this manner I can add and remove as many as desired.
The question is - is this a viable way to perform the action I desire? Will there be significant memory or performance issues if adding 100's or 1000's of objects?
// code from view model (using MVVM)
private static SimpleMarkerSymbol _pinSymbol = new SimpleMarkerSymbol(SimpleMarkerSymbolStyle.Diamond, Color.OrangeRed, 12);
private static readonly MapPoint[] _sitePoints = new[]
new MapPoint(-97.7805, 30.4027, SpatialReferences.Wgs84),
new MapPoint(-97.8005, 30.4227, SpatialReferences.Wgs84),
new MapPoint(-97.8205, 30.4427, SpatialReferences.Wgs84),
new MapPoint(-97.8100, 30.4227, SpatialReferences.Wgs84),
new MapPoint(-97.7900, 30.4027, SpatialReferences.Wgs84)
private void AddPin()
if (GraphicsOverlays == null)
return;
if (GraphicsOverlays.Count == 5)
return;
// how many pins right now?
var pinCount = GraphicsOverlays.Count;
var newPinIndex = pinCount;
var pinOverlay = new GraphicsOverlay();
var newGraphic = new Graphic(_sitePoints[newPinIndex], _pinSymbol);
pinOverlay.Graphics.Add(newGraphic);
GraphicsOverlays.Add(pinOverlay);
private Task RemoveLatestPinLocation()
return Task.CompletedTask;
int count = GraphicsOverlays.Count;
if (count == 0)
// update overlay
var removePinIndex = count - 1;
var overlayToRemove = GraphicsOverlays.ElementAt(removePinIndex);
if (overlayToRemove == null)
GraphicsOverlays.Remove(overlayToRemove);
