Hello everyone,
I wanted to check if anyone has had experience running any geoprocessing tool on-demand using Oracle and ArcGIS Pro. So my scenario is this (this is the simplified and most relevant version):
- A user enters data (which includes an address component) into a front-facing application
- User clicks a "Submit" button
- Data ends up going to an Oracle table
- Data is supposed to be processed with a geoprocessing tool
- Geoprocessing tool then stores the result back into another Oracle table
- User is able to see the result within the front-facing application
I already built the geoprocessing tool needed to process the spatial data using a model and can run it manually and it behaves as expected. But my question is, is there a way for the tool to automatically detect new records in the Oracle table in step 3 so that it can run by itself without my direct intervention?
I'm open to ideas and would very much appreciate your input!
